Overboost Problem lean codes... what is wrong ?
So I have had this over boost problem with my stage 2+ for a while now.. the chip is GIAC X..
I have been getting these codes...
17544 - Fuel Trim: Bank 1 (Add): System too Lean
P1136 - 35-10 - - - Intermittent
17884 - EVAP Leak Detection Pump: Insufficient Vacuum
P1476 - 35-00 - -
I have pressure tested the wastegate line and the intake.. I checked the fairly new 710Ns ..Didn't find a leak. I found that the small check valve that connects to the N249 valve was broken.. So I replaced it and it did not help.
I then proceeded to bypass the N249 to see if that was the problem and nothing changed.. I thought it could be my N75 so I replaced it and still nothing changed..
I checked to see if my exhaust was hitting that EVAP line and it was.. but I moved the exhaust a little and there is no hole or anything on that line to cause the EVAP code
When I put an MBC in place of the N75. Then it does not over boost..When the N75 is in, The actual boost goes past the spec boost then drops down then goes past it again.
There is also some weird part throttle hesitation..
My LTFT's don't look lean (see pic below)
<img src="http://pictureposter.audiworld.com/103335/ltft.jpg">
I'm stumped.. the boost will go over 20 psi on pump mode. In stock mode it goes to about 10.5 psi..
P1476 - 35-00 - -
Amato9588
05-31-2007 11:14 AM
