Overboost Throttle Cut (TC) Stage 2+ GIAC-X New Software checkout part II..
#42
Junior Member
but apparently not enough.
My max HP appears in the 4-5k rpm range - this based on my MAF readings. But, I don't get "throttle cut" from the ECU, only from my foot lifting off the accelerator. My VAG logs constantly confirm this (been logging this for the past year). Early this year - some folks in this forum cast doubt on my claim - so I posted the VAG logs - I've logged more since. I exeperience no hesitation at WOT or 4k rpm. Now, I am using lemmiwinks and it makes a difference in "smoothing out" the aggressive X chip.
just my $.02.
just my $.02.
#43
of a Lemmi tweaker, but the only one I saw that would have a direct effect on overboost is chan 12 SEL scaling (Turb Cars Only). This one has the problem of reducing the amount of boost across the board.
I am suprised that your MBC cannot get rid of these spikes or reduce them.
Bruce
Bruce
#46
differences between this build and MBC? I never did make it to MBC, decided to check this out first.
Bruce
Bruce
#47
When I was running v7a X software, MBC set to 16PSI, I was still experiencing TC. BAD. 3rd gear WOT would be very "hit and miss". Jumpy, watch the gauge hit 16, drop to 10, jump back up, etc etc. GIAC chip symptoms.
Same setting, new file. Car pulls HARD. Admittedly, the "*****-out" torque isn't there until 4500rpms, but there is no TC. The car pulls hard, 2nd and 3rd to redline, no TC, no hesitation. VERY smooth.
I'm sold, new k03 GIAC is worth the flash (it's flash only btw)
#48
The reason that I say this is that I was seeing some pretty bad TC (look at the blue curve on the thread of this post).. Now looks pretty good, no TC, no MBC. By the way, you said that you were going to send me MBC instructions, but never did.
Bruce
Bruce
LI-S4
01-19-2005 05:44 AM
Alright.. I'm officiating the contest for naming UrS4's new TB... (unofficially officiating, course)
snowman '92 100
12v V6 Discussion
11
03-04-2004 12:16 AM
VAP
12v V6 Discussion
11
02-23-2004 05:46 PM
