Overboosting problem...However a manual boost controller fixes the problem..so that means to me that
#16
Pressure test your system, check and re-check your wastegate lines, and ensure you have a good N75. Log boost and N75 duty cycle and see what is happening. ASP code, AFAICT, really doesn't use a lot of feedback to control the N75. Therefore, if everything isn't calibrated properly for your particular hardware setup, its possible to over or underboost. There have been plenty of people with this issue....myself included.
#17
hardware, and iirc the file he has only got 80% n75dc at midrange and climbing to 84% up top, he shouldnt be seeing over 22psi spike (lets just say give or take +/-22psi spike and taper to 20.5 or so
oh he has piggie dp and cats, shouldnt see that kind of boost unless his wastegate is stuck, couldnt open to bleed boost
