Part numbers for the S4 polished mirrors housings…
…for late 07/99 and later production.
These are the housings will all connectors, gaskets and sealers, motors. Pretty much everything except the mirror glass.
Passenger side (LHD models) 801-858-499-B-2ZZ
Driver side (LHD models) 801-858-500-B-2ZZ
Dm1200 a pair through a German dealer. But be aware most won't order without a VIN.
It might be easier to get a pair through you local dealer… as long as AoA has some warehoused on this side of the pond.<p>2000 Nogaro/Silver - S4
Reprogrammed ECU
"Dash T" TBB
Al Frt Susp
UUC Shifter (original 20%)
UUC VM1
S-02 PP
K&N
Reprogrammed ECU
"Dash T" TBB
Al Frt Susp
UUC VM1
S-02 PP
K&N
<p>'00 S4 Nogaro/Blue Alcantara
APR chip, UUC SS(40%), ITG filter
235/45 AVS Yoks, Smart Tire, Euro Headlights, Kamei grill, LLumar 35%, V1, JL Stealth box, Nokia Kit, Strat Mats, Rob ****(brushed)
Alan
Alan
Reprogrammed ECU
"Dash T" TBB
Al Frt Susp
UUC VM1
S-02 PP
K&N
Reprogrammed ECU
"Dash T" TBB
Al Frt Susp
UUC VM1
S-02 PP
K&N
the polished mirror housings are not available separately,you have to buy the complete mirror assembly(not cheap).you would also need to show a copy of your data sticker as this contains all of the build information relevant to your car(this is normally in the service book).there is about 3 options per side,and the codes on the sticker will determine which ones you will need.
Sturbod
07-12-2000 04:33 PM
2953
05-25-2000 01:35 PM
RS4.org - DaveH
05-04-2000 04:53 AM
