PDQ- Is too rich (ADD) codes 17545, 17547 from STFTs or LTFTs?
<center><img src="http://pictureposter.audiworld.com/44443/ltfts_090908_8.0_primary_fuel.jpg"></center><p>
codes are as follows:
Tuesday,09,September,2008,18:29:56:16665
VAG-COM Version: Release 704.1
Address 01: Engine
Control Module Part Number: 8D0 907 551 M
Component and/or Version: K0463085-93 G06 CPT4
Software Coding: 06711
Work Shop Code: WSC 79415
2 Faults Found:
17545 - Fuel Trim: Bank 1 (Add): System too Rich
P1137 - 35-00 - -
17547 - Fuel Trim: Bank 2 (Add): System too Rich
P1139 - 35-00 - -
Readiness: 0000 0000
LTFTs look like pic, which should not draw code?
Bruce
Address 01: Engine
2 Faults Found:
P1137 - 35-00 - -
P1139 - 35-00 - -
Bruce
I'm thinking that rich code may come from short term fuel trims (STFTs), not long term fuel trims (LTFTs). LTFT numbers look reasonable.
Bruce
Bruce
any type of injector constant that was changed in your code to account for the AFPR. Best bet would be to go to OE FPR and get retuned honestly. No need to run the 60#'ers that high; 4.8 IIRC?
Although the Hitachi MAF is much more reliable, I have still had a couple that will read too much g/s at idle and too little at higher RPM.
You might also be able to get more info in freeze frame (when it happened, RPM and temp?) with the generic OBD function in VAG-COM, can't remember on our cars.
I think must come from STFTs (guessing).
Bruce
Bruce
and also "With this malfunction the exhaust Malfunction Indicator Light is only switched on by the ECM if the malfunction is recognized after the engine has been restarted."
Check page 47. Doesn't say any of the P or VAG codes relate to short term trims.<ul><li><a href="http://www.vaglinks.com/Docs/Audi/C5/BentleyPublishers.com_Audi_C5_OBD_Diagnostics.pdf" >http://www.vaglinks.com/Docs/Audi/C5/BentleyPublishers.com_Audi_C5_OBD_Diagnostics.pdf</a</li></ul>
deviation from the MAF maps is actually 17.7 on bank 1 right now. What have you done in Lemmi? Your FP is definitely different than when it was tuned so I'd be worried you're dangerously lean at WOT...
