pic's of porsche brakes on a S4
Here are some photos (low quality) posted by somebody else on this forum over a year ago.
<center><img src="http://albums.photopoint.com/j/View?u=40497&a=13612416&p=56701457"></center><p><img src="http://albums.photopoint.com/j/View?u=40497&a=13612416&p=56701456">
why get porsche brakes when you can get stoptechs for less?
stoptechs are designed FOR the S4, while porsche brakes are brakes designed for the porsche which just happen to fit the S4.
And stoptech have a floating rotor design while porsche are 1 pc.
Porsche brakes are also just Brembo brakes...
not actually made just for Porsches, they're just standard Brembos with Porsche printed on the calipers instead of Brembo hehehehe.
I agree, StopTech is the way to go.
Brembo Kits and Movit Kits are Different
<center><img src="http://www.ultimategarage.com/Movit17.jpg"></center><p>First of all, the president of Brembo NA may contact you to retract this comment. He has contacted me in the past and asked me to stop making comparisons of Movit's brakes to Brembo brakes. You can say that Movit uses Brembo made calipers that have been engineered by Porsche and Brembo.
The 322mm and 380mm rotors are 2pc. The big advantage Movit has over Stoptech (at least for now) is the availability of a complementary rear kit this is very effective in balancing the overall braking. Stock S4 rear brakes are very tiny (stating the obvious).
For an overview of how Movit makes their brakes, see the URL below. Every aftermarket accessory installed in Europe is subject to inspection by the TUV. I suspect many of the modified S4's on this list would not pass this strict inspection.
For those going to the Essen show this week, Movit will have a strong presence there. SD<ul><li><a href="http://www.ultimategarage.com/movitkit.htm">http://www.ultimategarage.com/movitkit.htm</a</li></ul>
Audone
22
05-18-2007 09:25 AM
Found interesting post by Bob Lee explaining why Stoptech ST 40s are superior to Porsche Big Reds...
Auto Union Jack
45
11-04-2002 06:57 AM
Root Down
07-31-2000 10:31 AM
