Piggie pipes throwing codes
Just did my downpipes { guted pre-cats } a couple of days ago and I'm getting codes # p1113 - p0102 - p1128 - p 1130. I"M NEW AT THIS. Any one see a trend that points at a problem?? Thanks for your help.
I took the set out at the front of the rear cat -- then welded a bung in the rear of the rear cat and put the sensors there - does that make sense?? In any case, I have a cat between the sensors -- which is what I'm after?
17521
P1113
Bank1-Sensor1 Internal Resistance too High
16486
P0102
Mass or Volume Air Flow Circ Low Input
17536
P1128
Long Term Fuel Trim mult.,Bank1 System too Lean
17538
P1130
Long Term Fuel Trim mult.,Bank2 System too Lean
Check all sensor and MAF connections.
P1113
16486
P0102
17536
P1128
17538
P1130
N9909E
04-01-2006 01:15 PM
dano-oly
04-18-2005 09:59 AM
WoostaS4
01-31-2003 06:41 AM
