Placing parts order for aux coolant pump replacement.. want to make sure i have everything...
The dealer mentioned a sensor or fuse i need to replace but i cant find such? I was also surprised the mani gasket was $4/per side... can someone who has done the job check the order im about to place? I want to make sure i have all the hoses etc. Im looking at placing the order w/ ECS because they seem to have everything i need...
OEM Coolant Hose ES#6801
"L" shaped hose from side of auxillary water pump to rear water pipe $11.29
Ships 1-3 days $11.29
OEM Coolant Hose ES#6800
Hose from water pipe to the front of the auxillary water pump $6.49
Ships 1-3 days $6.49
Auxiliary Water Pump ES#2710
Electric water pump $109.95 $109.95
Intake Manifold Gasket-Priced Each ES#2633
Fits left or right bank $4.05 $8.10
Thanks again for everyones help!
Pick up a variety of clamps. I got 2 bags at Lowes. One of the smallest size and one of the next size up. I replaced the aux pump stock clamps with screw style clamps. You can take in the new hose to verify the size.
Make sure you have a magnetic pick-up. You will need it...
Not sure what mods you have or plan on having, but it's a good time to throw in Phenolic Spacers if you will ever be heading in that direction.
It's really a pretty simple job... 4 or 5 hours the first time you do it.
-Matt
-Matt
Floydo
04-08-2011 03:41 PM
rakta *chchchanges
9
07-15-2008 03:55 PM
clinton c
03-01-2007 05:48 AM
shazam123
Audi 100 / A6 (C4 Platform)
12-01-2005 06:11 PM
