Planning to get rs4 reps 18x8.5 30 offset will I run into any rubbing issues with 235 40 18 tires or
And 215/40/18 tires and I was pretty slammed. 235s will definitely rub... you can get away with 225s. You'll have a bit of stretch.... so it's up to you if that's the route you want to go. My 215's had ALOT of stretch.
Also keep in mind it depends what brand of tire you go with. Not all 225s are created the same.
