PLEASE HELP IMMEDIATELY!
my car is overheating. after the thermostat needle went to 5/6 of the bars, the overheating warning came on.
I was about 1/2 mile from home, so i drove home slowly and popped the hood. At first i thought maybe i was low on coolant.. so i slowly opened the coolant reservoir. I noticed the coolant was BOILING!! and it rushed out.. leaking everywhere. I closed the cap, came back a hour later, filled it up with more coolant.. and thought i would let the car sit for a few hours. a few hours later, i drive it for a few miles. When i started the car, the needle is all the way left.. for most of the trip, it is in the middle (50%:: normal) but the needle was slowly rising and by the end of my trip the overheating warning came on again...
i have 90K miles... is it the water pump? thermostat? i go to UC San Diego (originally from sacramento) and was planning to drive my car back up to Northern California next friday (dec 9th).. but i guess not.. not with this problem. Im not gonna drive my car any more till I hear from you guys. Please respond immediately, thanks!! i really appreciate it. I searched a little on the forum archives, but i couldnt find a cause-effect directly relating to the waterpump or overheating in general.
email: rsachdev@ucsd.edu
phone: (916) 837-3514
aim: ricencurri
thanks again guys, i will check the forums every 30 minutes as well
aim: ricencurri
highway speeds it is most likely your thermostat.
My thermostat went out recently & it would get hot regardless of the speed I would drive. If it was a fan problem, you'd be overheating in traffic but at highway speeds there is enough airflow to keep it cool.
no not yet...
is the thermostat something i can replace myself? does my thermostat need replacing, or repairing?
It may be worth doing the timing belt, tensioners & water pump at the same time since you have to have the front end of the car off to get to them. Plan on $1100 to have all this done at a dealership.
Feel your radiator, if it's relatively cool, your 'stat isn't openening properly. If you have a leak, well, the repair for that is obvious.
There are also some more sinister possibilites too... but these are the most likely.
