Poll for ASP stage 3 folks that had/have misfire CEL.
Switch to EPL... LOL! I never got idle misfires to go away with 42lb setup. Coilpacks helped, new plugs helped, but no cure. I switched to EPL for local tuning capability... so far no misfires (knock on wood), 1 day only. ;-) )
seems to be mainly cylinders #5 and #6. Happens more often lately....even had #5,#6,#3,and #4 misfiring last time I cleared the CEL.
This issue has been around since day one after the install....ASP even acknowledged it when I picked the car up and attributed it to the X-1.
I plan to have a retune done to resolve the issue.
lemmi and add torque bits in multiples of 5 until your idle load is 18%. if you still dont see misfires - well then you really dont have any misfires
If you add idle torque with Lemmi in order to see misfire recognition enabled, you won't get a clear picture of how your car idles with normal idle torque.
My car usually idles at 16-17% load after scaling idle MAF readings. I used to idle below 15% load and never had idle load misfire recognition enabled. Regardless, I modified the code so that idle load misfire recognition threshold is only 15% now.
