Poll for ASP stage 3 folks that had/have misfire CEL.
#32
On some files, I dont throw misfire codes. On some files, I've had misfire codes only. On one file, I triggered a CEL. The differences between them were MAF/fuel corrections.
#33
Kinda weird that swapping 2 with 5 finally cured it, I suspect there is another injector or CP that is on again/off again OK / on its way out, wont know till it gets worse, but car is 95% OK now which is fine as I rarely go WOT. Mark was/is willing to look at the car again, after already spending 8 hours of follow-up work since St3 conversion, but its good enough for me now.
#34
like i said from previous post, i have had flashed multiple cars with the same identical file, how come some of them are just dead zero, some of them had mis-fire? btw, these cars as almost identical hardware
#38
but like i said we are going to try swapping POS and Coil Pack and see if it helps, next would be checking vac leak if first 2 didnt help!
hang tight with us! I promise you that you will be happier then ever!
btw how is the power so far?
Bebee
12-16-2007 05:51 PM
laissezfaire
17
06-24-2007 09:47 PM
'Nova more S4
10-01-2003 09:17 AM
