Popping noise in exhaust
Just installed Milltek Superduals. When I accelerate quickly in 2nd then let off the gas I hear a low sounding "pop-pa-pop-pop." Is that normal or a leak of some sort?
2001.5 Tiptronic - Stock, except Milltek pipes and Milltek DVs.
THANKS!
THANKS!
a heat sheild. Mine was rubbing up by the Y divider, i just had to reajust....does it make the popping noise more when the engine temp is hotter, cause that would make sense....and mine did it mostly under decel. this happening w/ the superdaul makes sense also cause i've heard that its almost too wide under there and may rub.
naw. The off-throttle sound is just monsterous. I LOVE IT! Just the knocking between shifts was a bit suspect. I'm gonna go to a pipe shop and have an adjustment. I think it's hitting a control arm down there.
PSmalls::DoggieStyle
39
04-04-2005 09:01 AM
christopherjs
12
08-17-2003 10:31 AM
0!1qu!ckAvant!
01-27-2003 10:35 AM
HaVoC
10-27-2002 08:19 PM
SwifTT
19
12-04-2001 07:18 PM
