Is the power seats in the 01 S4, the same as the A4 say 97-01
I might sell my seats to another audi owner, but I need to know if the power seats in the S4 and A4 is the same. for example motor, harness, connectors...
thanks in advance...
I took my S4 seats out and could have sworn there are only two rails. All the motors are built into the seat itself. So if you just put the seat on the ground and plug it in you should be able to make all the adjustments. That leads me to believe you could swap the A4 / S4 seats. As long as there is a harness connector to plug them in.
The S4 seats are much closer to the 'Sport Seats' option from the A4 (I had a 98 A4 with standard seats, my wife has the sports).
Also, the quality of the leather on the S4 seats in Onyx is much nicer than that that was on the A4 in Onyx.
There is a difference between the A4 manual and S4 powered seat bracket.
However, I believe the A4 powered seats use the same mounting points as the S4 seats.<ul><li><a href="https://forums.audiworld.com/s4/msgs/565463.phtml">https://forums.audiworld.com/s4/msgs/565463.phtml</a></li></ul>
No one is for sure if the A4 and the S4 share the same hardware when mounting the power seats.
Let me clarify...
Can I stick my S4 seat in the A4, and vice versa... without any modification...
Let me clarify...
KevCK
07-18-2005 05:30 PM
quattro25
Canadian Discussion
06-22-2005 06:35 AM
Al G not algae
03-30-2002 05:14 AM
