power steering fluid leaking - most likely (lines ? pump? reservoir?)
one clamp was a bit loose righ under the power steering fluid tank , and another right above the power steering cooling line.
look for dirty spots inside the engine bay , behind the driver's side headlight , directly under the TBB , and right above the tranny behind the engine. also look uder the car between the driver's side intercooler and radiator .. you'll see the power steering line to/from the cooler there.
i hope this helps Paul.
If it is dropping and you cannot find a leak, I have a guess.
Just found a leak on JasonS4's car. The hose from the pump over the engine block (but under the intake manifold) was leaking. Not easy to find or get to. I imagine you have to pull the manifold. The hose is $150 from 1stvwparts. Over $200 everywhere else.
I hope that isn't it.
under intake manifold to back of the engine. If you see fliud on the top of the engine the it is probably the hose.
greenaudi100german
03-01-2008 05:26 PM
tk1780
Audi 100 / A6 (C4 Platform)
02-18-2006 04:25 AM
