Presenting Zero Clearance K04s!
Old 12-18-2003, 12:54 PM
  #21
Elder Member
S4mig@PEB tuning's Avatar
Default Since the compressor side is more efficient, then turbo life is extended
The shaft clearance remains unchanged, it the clearance of the blades to the housing that becomes better. Less heat. more output = happy turbos.
Old 12-18-2003, 12:56 PM
  #22
Imolavirus@BuehnEngineering's Avatar
Default unless there is oil contamination.......
the side play in the shaft wont increase at any measurable amount. the wheel will wear its pattern into the housing in the first few hundred miles after start up.
Old 12-18-2003, 12:57 PM
  #23
Junior Member
Bryan Slowgaro's Avatar
Compressor efficiency. It's a pump with fewer leaks.
Old 12-18-2003, 12:59 PM
  #24
oopps, did i leak info again? i suck at this : )
  #25
wishbone's Avatar
Good news, I anxiously await the larger solution as well as dyno numbers on this one..
Old 12-18-2003, 01:02 PM
  #26
R1ce's Avatar
Default <Burns voice> Excellent.... </Burns Voice>
I'm glad I've held out on new turbos this far, this is what I've been waiting for.
Old 12-18-2003, 01:08 PM
  #27
Member
BASELINE's Avatar
Default Nah...I figured it was KKK, I know you are a dealer....i guess I was just hoping it was...
a Garrett Dual ball bearing... Are the Zero Clearance Turbos louder or quiter than the regular blowers.
Old 12-18-2003, 01:10 PM
  #28
'Nova more S4's Avatar
I think I should do some tests on what power increases it brings to a non-chipped car. :-)
  #29
Member
Marin S4's Avatar
Default Glad to see you thinking outside the box....
Can you say who will be doing the software on the much larger turbos?
Old 12-18-2003, 01:11 PM
  #30
AntiSocial's Avatar
Default ::preparing for onslaught of trolls::
Good work, Josh, keep the good stuff rollin!
Quick Reply: Presenting Zero Clearance K04s!
