pressure test help - how do i remove this hose clamp?
<center><img src="http://pictureposter.audiworld.com/88125/pressure_test.jpg"></center><p>found a small leak on the underside of the T junction, how do i remove these clamps and can i get replacement ones at home depot?
get some vacuum hose at any automotive store, and use small zip ties to hold it on. its like 68cents per foot for some good vacuum hose. bring that piece with you, make sure the stuff you buy has the same inner diameter as the stock hose.
the places usually keep the vacuum hose in the back, so you have to ask for it.. dont go looking for it, not see it, and then leave
<ul><li><a href="http://www.awe-tuning.com/media/pdf/27t_pressure_tester.pdf">http://www.awe-tuning.com/media/pdf/27t_pressure_tester.pdf</a</li></ul>
