Problem with aux fan in front of radiator. Always running on high speed.
Yesterday I noticed a high pitched whine coming from the front of the engine bay right after I started the car and turned on the A/C. When I turn off the A/C the sound goes away but as soon as I turn it on again the sound comes back. Searching the archives it seems that this is a common problem with the aux fan getting stuck in a high speed mode either because of a bad relay or something obstructing the radiator fan from turning. I checked while the car was running and the raditor fan was turning so I don't think that's it. By process of elimination I'm assuming it's either a relay or some type of thermostat or sensor. Is there an easy fix to this problem? If it is just swaping a relay, where is the relay for this. Last time I remember looking under there, there were a couple of relays right next to the fuse block. How much does a new relay cost? TIA
I thought the fan was temperature controlled so it shouldn't be going on as soon as the A/C turns on. Shouldn't it only turn on after it senses a certain temperature has been reached?
According to pages 11-13, it looks like I may have a thermoswitch or pressure switch problem.
amicus
08-29-2023 03:10 AM
in2audi
05-20-2005 05:27 PM
RussB
01-19-2005 03:17 AM
Luxus Panzer
9
04-25-2004 10:38 AM
