Programing Key Fob Problem
I know that this has been posted in the past but there does not seem to be a answer to my problem.
My only key fob does not work after I changed the battery. When I followed the steps to program it the only thing that worked is when I locked the trunk and pushed the unlock, then the back lights blinked once and only once no matter how many times I hit the unlock on the fob with the other key in the ignition. Has anyone figured out how to program the FOB from the trunk and with the driver side lock removed??
If someone can contacted me on how I can put back the driver side lock which I do not have and still not be vulnerable of the car being stolen from the driver side lock.
A few other posts with the same problem but no real solution.
https://forums.audiworld.com/s4/msgs/1819329.phtml
https://forums.audiworld.com/s4/msgs/2085413.phtml
Thank you
Thank you
They programmed it for free. I do live 2 miles away from my dealer, and they are actually a good dealer. You may not be so lucky. Sorry I can't provide any useful information.
Guest
read the last sentence carefully... I always ended up with one key working until I reread this tech article.<ul><li><a href="https://www.audiworld.com/tech/misc13.shtml">https://www.audiworld.com/tech/misc13.shtml</a</li></ul>
Thank you, I just tried that. The car only blinks once and nothing else.
I am ordering the VAG-COM soon, can I program the key FOB by the VAG?
Guest
for the 2nd....
I had to print this tech article out, take it to the car and do it a few times until I had it down.
Where are you located?
jbrinton
11-09-2006 04:03 PM
penguin101b
08-20-2006 02:22 PM
fe342185
11-06-2002 06:19 PM
