Pulled engine for 3rd time this year - this time to replace the tranny...
AudiWorld Expert
I recently went to the drags and jammed 3rd gear for a final time, as both 3rd/4th refused to go back into gear. I picked up a used tranny from a '00 A6 2.7T and put it in over the weekend with the help of DAP. I was happy to see that the donor car was a tan A6, because nobody drives a TAN A6 aggressively ;-) It took just under 5 hours to get the engine/tranny out of the car, a couple hours to switch over the transmissions, and then just under 5 to put it all back together. Dave and I had each pulled our engines twice this year, so by now we're pros and it went quite well ;-)
The only catch along the way was that the reverse sensor on the A6 2.7T is different than the S4. The sensor housing has a different mounting location that a shifter linkage bolts into. The S4 linkage wouldn't mount to the A6 sensor housing, so we swapped sensor housings and all was well.
I now have all 7 gears back and I'm very happy. I figured it'd be a good idea to press my luck and go to the drags on Wed night... hey, I have ~9 gals of 104oct just begging me to use it up
<img src="http://ctny.audiworld.com/mark/s4/maintenance/tranny_replace/DSC04396.JPG">
<img src="http://ctny.audiworld.com/mark/s4/maintenance/tranny_replace/DSC04397.JPG">
<img src="http://ctny.audiworld.com/mark/s4/maintenance/tranny_replace/DSC04398.JPG">
![Embarrassment](https://www.audiworld.com/forums/images/smilies/redface.gif)
AudiWorld Expert
not sure just yet. I'd really like to open it up and work on it, but I'm not sure what tools I really need to invest in to do the work properly.
AudiWorld Expert
the 2000 A6 2.7T 6-speed lists:
https://www.audiworld.com/model/a6/00/specs.shtml
Gear Ratios:
1st
2nd
3rd
4th
5th
6th
Reverse
Final Drive
Manual
3.500:1
1.889:1
1.231:1
0.987:1 <----
0.806:1
0.684:1
n/a
4.111:1
The 2002 S4 Avant 6-speed lists:
https://www.audiworld.com/model/s4/02/avant.pdf
Manual
3.500:1
1.889:1
1.231:1
0.967:1 <----
0.806:1
0.684:1
3.455:1
4.111:1
Note the minor difference which I assumed was just a documentation error. I looked at all years ('00-'04) A6 2.7T and they all list 0.987, while all years ('00-'02) S4 list 0.967. I find it quite strange if they'd really put such a small difference in gear in one gear in this otherwise identical tranny. So, again, I assume it's a documentation issue. At some point I'll log gear/speed/rpm to see if it matches my older logs, though I might not be able to capture such a small difference anyway - we'll see.
Gear Ratios:
1st
2nd
3rd
4th
5th
6th
Reverse
Final Drive
Manual
3.500:1
1.889:1
1.231:1
0.987:1 <----
0.806:1
0.684:1
n/a
4.111:1
Manual
3.500:1
1.889:1
1.231:1
0.967:1 <----
0.806:1
0.684:1
3.455:1
4.111:1
