pulsing turbo and low boost after extended in-town driving
#11
Sounds like you're dropping into limp mode.
Most common reason on the 2000's is a bad MAF.
Find someone near you that has a VAG tool, and scan for codes - you probably have some lean codes.
-T
-T
#12
Re: Sounds like you're dropping into limp mode.
I do have a vag tool, I have been told to look for the a/f or lambda ratio (block 031) but I do not have a check engine light come on , I will scan it tonigh and see if I have any code when it does it, or is there an other block I should measure BTW we have the exact same baby blue same option and colors,,
#14
I have scan the car for codes and I have 2 the 1st one is a 17862 exhaust gas sensor short to grd and 17745 camshaft position sensor short to grd, I will diagnostic the two sensor but any expanation on why what who where welcome
iconoclast
32
05-21-2007 06:52 PM
S4@last!::Now B7 RS4
43
05-03-2004 09:31 AM
Pop3
08-28-2003 03:32 AM
S4stylin TMK
12
05-15-2002 09:58 AM
