Q: boost buildup without N75 active?
trying to diagnose a mild stuttering that happens while keeping the throttle constant, i logged my commute to work one morning. it's only about 5mi and the engine barely warms up. so i try to keep the RPMs under 3000 and no boost (at least according to the boost gauge).
what i noticed was that i'm building boost, yet the N75 is not even active. at some points the boost is up to 4psi and the ECU's not requesting any.
i was thinking at -5 or 0 PSI the BPVs are probably closed, but isn't the boost primarily controlled by the N75/wastegate?
i dont understand:
1) where the boost is coming from
2) why the ECU is not throwing a deviation code
3) why the boost gauge & MAP readings differ
<img src="http://us.i1.yimg.com/us.yimg.com/i/mesg/emoticons7/39.gif">
<img src="http://bagodoosh.home.comcast.net/s4/Boostage.gif">
i dont understand:
MAP sensor is before the throttle body, so you could have some boost there but still vacuum in the manifold because of the throttle plate position.
HTH,
mihnea
HTH,
mihnea
ImQuattro®
Audi Original "S" Cars
01-27-2009 01:12 PM
ski ya later
05-12-2006 12:08 PM
mdwsta4â„¢uroslut
07-17-2002 02:24 PM
