question about tdc and leak down test
is there a better way to find tdc than using a long *** screw driver? my engine has the crank lock pin installed right now that mean 1,3,5 are at tdc right? if so rotating the crack over one time till the mark on the harmonic balancer meets the arrow again means 2,4,6 will be at tdc???
whats the firing order, is it :
FRONT
1 2
3 4
5 6
also what PSI should i use for the leak down test
thanks in advance
FRONT
1 2
3 4
5 6
thanks in advance
Remember, it's a 4 stroke engine.
You'll then need to hand crank the engine in the firing order to get to each of the next TDC's per cylinder.
FatAuto
07-25-2007 12:00 PM
Lutz
08-31-2005 06:59 PM
Afroide
06-26-2004 07:34 PM
Ben's e//S2
07-16-2003 07:31 AM
