Question on oil lines for 5/00 build date
Were the oil lines updates like it was for 11/00 and later build date? If not, did somebody try to have them replaced whithout the turbo failure?
Do you think it is possible to talk AoA into replacing them with turbos still working properly?
Any info will be greatly appreciated.
Yuri
Yuri
Someone posted 10 - 12 months ago of superimposed images of their factory turbos with those replaced under warranty and the oil inlet on the turbo housing was about 60% larger. Additionally, our OTS said there are differences in the turbines. Updating the oil lines may or may not provide much benefit.
but if you have concerns, get them documented. I believe Audi will stand behind the pre 2001.5 cars especially and fix bad turbos even after warranty expires, as long as you can get some other ducks in a row. I may be dreaming, but this is based on conversations with AOA. Of course if you chip then all bets are off. YMMV
(R)S4 SmokedU /-///
44
01-26-2008 04:46 AM
M3iRiSH
13
07-10-2002 03:09 AM
2.7t john
06-27-2002 12:24 PM
