Question for Stage 3 installers
Guest
Posts: n/a
then drill a hole in the same location and insert the grommet. NOTE: it's recommended to make sure the hole you drill is a bit SMALLER than the one in the stock hose, that way the grommet is very tightly fitting and will be less likely to pop out.
