quick shifts
quick shifts
Has anyone when accelerating hard from 1 to 2nd get a grind going into second? Ive been trying different methods of getting a clean shift but if I am really getting into it it will grind going into seconds and sometimes miss the shift so I'll double shift. TIA
Re: Either you can't shift or you have synchro issues.
I'd say synchro because even under a soft shift it feels wierd going into 2nd. Plus it has never happened with any other car I've driven so I'm pretty sure after 15 yrs. of shifting I have it down pretty well, but thanks anyway. I was more wondering if anyone had 2nd gear sychro problems.
Re: quick shifts
I had the same problem with only about 5000mi on my car. The dealer said that they had replaced a large amount of s4 transmissions with the same problem. They ended up replacing the transmission. I would suggest getting it in to your dealer, because on my car it only got worse
Re: quick shifts
We have had big problems with th 01E 6 speed almost always with the 1-2 shift hub and syncros, I personally have rebuilt at least a half dozen. Good luck make sure wherever you bring it they have someone trained to repair it.
Bazzy
04-27-2021 06:28 AM
2001SilverS4
12
04-03-2006 02:12 PM
Phil G.
10-24-2004 07:13 PM
SawyerA8
12-30-2002 02:48 PM
