Re: The Electronic Throttle Control, how do you know when it goes bad? What does the car do?
if one of the potentiometers on the pedal assembly goes, throttle input should stay pretty normal as the other one will take over - if the actual throttle body goes the car will go into an emergency mode to allow you to get to a safe location to stop. its all in the 2.7T SSP.
If you have VAG you can check the % of each pot in the gas pedal. They're inverted, as in one is 100% while the other is 0% and vice versa. Although you rarely see 100 and 0 for actual numbers. Check that first before you drop big bucks on a throttle body.
A6Fanboi
12
01-14-2007 09:19 AM
scotty slc
10
12-28-2002 01:01 PM
