rear passengers window problem (drivers side)...
When trying to roll up the rear window I heard some breakage. I was out and about and couldn't get to it right away so I tore into the problem today. Anyhow I found a white plastic wheel, bigger than a silver dollar, busted into 3 major pieces at the bottom of the door. I haven't got a clue to where it goes yet (will probably look at the other door) but I do know that the cable wraps around it somehow. Can someone point in the direction to get another one and can I use the other sides part to get the window up until I get a new part?
You need a new window regulator. The white pulley is part of it and cannot be purchased separately.
The window regulator is riveted into the door/window frame.
If you want, later on I can dig up the part number.
I just replaced mine no more than a month ago for the same exact reason. I just forced the window up and secured it with zip ties.
Here's the tech article with part numbers and tools needed...
<ul><li><a href="https://www.audiworld.com/tech/int65.shtml">https://www.audiworld.com/tech/int65.shtml</a</li></ul>
I caught the link, thanks
I went to the dealership and returned the part, I also used your suggestion of zip ties to keep the window up. This should be sufficient to keep rain and critters out until the new part is received and installed. Thanks for the help.
Adrien A4
05-10-2004 07:27 PM
Philipp DJ
04-22-2004 12:29 PM
qwertyuiop[as
10-31-2003 09:01 AM
kent@thething.org
12-07-2002 06:24 PM
