Refilling coolant, any particular proceedure to get out the air in the line?
On my wrx it is common to fill the reservior and then "burp" the lines. The Audi has a completely different setup, one bottle (not 2), is it as simple as fill and go? Reason being that the lower lines were removed for an oil cooler install and all coolant is now in a bucket. Thanks in advance.
you can just fill and idle and fill, check levels the next day and top off if needed.
Make sure you got the "cirrus" clips back on the radiator hoses :P
add coolant while idling, keep the cap off, rev the engine a bit, level will go down, add coolant again... repeat until coolant level in the radiator remains the same
<center><img src="http://www.achtuning.com/images/rs4oilcoolerinstallguide.jpg"></center><p>
LordKarnage17
10
01-10-2018 05:30 PM
