Is the relationship between car weight and
acceleration linear? If, we shaved off 500lbs off an S4, which would be 500/3600 = ~14%, would 0-60 and 0-100 times be reduced by 14%. So, a 0-100 time of 15 secs would become 12.9 secs? I know that the relationship between HP and acceleration is definitely not linear but what about weight and acceleration? Has anyone experimented with this to test out how weight savings improved performance? Just being a curious george.
wouldn't change, and the rolling friction would only be slightly less. Also a lighter car cannot apply as much force to the ground. It wouldn't be accurate to neglect all of those factors. Also, where you save the weight makes a difference reducing rotating mass will have a greater effect than non-rotating.
So if your S4 does the quarter in 14.10 seconds and you dropped 500 pounds, you can expect to be around 13.60.
all else being equal, the et and trap speed are a function of the square root of the mass.
et = square root( 2 * Distance * Mass / Force )
speed = square root( 2 * Distance * Force / Mass )
Of course your comments are correct.
EighTT
05-14-2002 06:43 AM
quickersilver
54
12-03-2001 09:25 AM
