Release of GIAC 3- software (K04's stock MAF and injectors)
Old 07-11-2005, 08:53 PM
Senior Member
J.Moss@TorqueFactory's Avatar
Default Release of GIAC 3- software (K04's stock MAF and injectors)
Hi Everyone,
GIAC has just released the 3- software for the B5 S4.
This software was developed to meet the need of many who wanted a cost effective trouble free way to install k04 turbos. It was set up and tested with a Bosch Motorsport 5 bar fuel pressure regulator and off the shelf K04 turbos. The regulator is about $200 at this time and the software is $800. You will be able to trade in your old GIAC chip. Ask your dealer for details on a credit.
If you have an ā€oeAā€¯ box car it will need to be converted to a Hitachi MAF, an ā€oeHā€¯ box 2001 will need a simple recode to use ā€oeMā€¯ code. Thanks to Mike Shimon for the knowledge on how to do this! The instructions and parts needed to install the Hitachi MAF have been sent out to the GIAC dealer network along with the new software.
The software was setup to use the existing hardware as far as we were comfortable taking it with the stock injectors and MAF. 1.3 bar peak and 1.1-1.2bar at 6500 RPMā€<sup>TM</sup>s.
Long term fuel trims as tested with the Bosch 5 Bar were less than 4% negative across the board.
Please be aware that this is not intended to replace real ā€oeStage 3ā€¯ tuning. Adaptation channels have been turned off as the injector on time is very high and GIAC does not want any hand in causing possible damage to your cars.
I hope you all enjoy this setup!
Jeff Moss
Old 07-11-2005, 08:55 PM
Imolavirus@BuehnEngineering's Avatar
awesome Jeff, glad this could come to be
Old 07-11-2005, 09:00 PM
Member
KOpork's Avatar
Good to hear and good to hear a tuner complimenting piggy when he helps someone out.
Old 07-11-2005, 09:13 PM
Member
vegasS4's Avatar
Default Cant wait to feel the code. Adaptation turned off, so 91 or 93 octane will yield same power? what..
about race mode will that still be available?
Old 07-11-2005, 09:14 PM
Bauer's Avatar
Default Good work Jeff.
Hey how are things, good?....sounds like you have been busy.
Old 07-11-2005, 09:21 PM
Former Vendor
SIMPPLY @ WMS's Avatar
nice work !
Member
KOpork's Avatar
Asking the wrong person.. :-) Jeff care to answer?
Old 07-11-2005, 09:22 PM
Senior Member
Default Re: Good work Jeff.
Thanks Ben,
Ben busy. Have been setting up wholesale accounts and the training and setting up is taking a bit of time. It is all fun!
The new 91 octane stuff is looking really good. Will get in touch with you when it is all nailed down.
Say hello to Jen.
Jeff
Old 07-11-2005, 09:23 PM
Senior Member
Default Re: Good to hear and good to hear a tuner complimenting piggy when he helps someone out.
You need to give credit where it is due.
Old 07-11-2005, 09:25 PM
Member
KOpork's Avatar
Glad he has finally gotten some of the credit he has brought to the community.
Quick Reply: Release of GIAC 3- software (K04's stock MAF and injectors)
