Replaced Spark plugs. .Now getting Misfires code ... !!
Well, I left the inner light on for a few days (Genious !!). The battery went dead. So I had to jump the car & recharged the battery.
Replaced the spark plugs today with NGK BKR6E's. Gapped at 0.030". Drove it around for a while, felt hiccups on a few occasions. Came back home, vagged & got the following codes.
Can the change of spark plugs cause misfires ???
Car is ASP stg2 chipped.
Address 01 -------------------------------------------------------
Controller: 8D0 907 551 M
Component: 2.7l V6/5VT G 0002
Coding: 06711
Shop #: WSC 13622
7 Faults Found:
16815 - Warm Up Catalyst: Bank 2: Efficiency Below Threshold
P0431 - 35-10 - - - Intermittent
16805 - Warm Up Catalyst: Bank 1: Efficiency Below Threshold
P0421 - 35-10 - - - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - - Intermittent
16687 - Cylinder 3 Misfire Detected
P0303 - 35-10 - - - Intermittent
16690 - Cylinder 6 Misfire Detected
P0306 - 35-10 - - - Intermittent
16686 - Cylinder 2 Misfire Detected
P0302 - 35-10 - - - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03 -------------------------------------------------------
Controller: 8D0 907 389 E
Component: ABS/ESP allrad D46
Coding: 04395
Shop #: WSC 06435
1 Fault Found:
01435 - Brake Pressure Sensor 1 (G201)
Address 35 -------------------------------------------------------
Controller: 8L0 862 257 N
Component: CV-Pump, Alarm, RC D16
Coding: 16232
Shop #: WSC 12345
2 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
00991 - Interior Lights
28-00 - Short to B+
Address 56 -------------------------------------------------------
Controller: 8D0 035 195 A
Component: Radio D00
Coding: 00110
Shop #: WSC 06435
1 Fault Found:
65535 - Internal Control Module Memory Error
00-00 - -
Coding: 06711
Shop #: WSC 13622
7 Faults Found:
Coding: 04395
Shop #: WSC 06435
1 Fault Found:
Coding: 16232
Shop #: WSC 12345
2 Faults Found:
35-00 - -
28-00 - Short to B+
Coding: 00110
Shop #: WSC 06435
1 Fault Found:
00-00 - -
