Replacing Side Marker Bulbs?? just pop off?
wondering if i can just pop out my side markers from the outside to replace the bulbs or if i need to take off the inside door panel and some sort of screws? any suggestions on the easiest way to the bulb. are they standard small wedge bulbs? thanks a lot!
Re: Yep just pop them out....best to put some tape down first, then just wedge them out
what do u mean put tape down first??? and do i pop the actual housing or just the lens?? thanks sorry for being such a no0b. :P
so whats the trick to not breaking the plastic tabs??
start from one side or the other?? top or bottom?? now im scared because i obviously dont want to drive around with side markers hanging out.
i can't find instructions on changing light housings on this car anywhere. seems sad since this is basically the a4 body.
i started from one side, if you are looking at it, start on the right side... wedge out very slow..
it depends really on how old the plasitc is i guess, its quite fragile.. dont worry if it brakes, you can always go rice, and double side tape it.. or you can glue the broken piece back together with supergllue,..
just go for it.. 16$ is the most youll pay to replace..
This is from the Service Manual
<img src="http://pictureposter.audiworld.com/76357/sidemarker.jpg">
Removing
- Press side turn signal lens against retaining tab in direction of arrow and carefully remove from fender opening.
- Carefully pull housing -2- out of rubber socket -1-.
- Bulb -3- can be pulled out of rubber socket -1- for replacement.
Installing
- Install in reverse order of removal.
Removing
Installing
gimp2.7
01-04-2005 07:50 AM
A4Jared
04-27-2004 11:21 AM
audifool
04-14-2001 10:22 PM
