Repost for night crowd: APR releases Anti-Theft System for S4...
Worried about your S4 getting stolen? Check out our new Anti-Theft system available immediately for the Audi S4. This system has been incorporated into the Bosch Motronic engine management system and will render your car immobile until the correct access code has been entered (using your cruise control stalk.) Adding this system to your car requires no additional hardware other than our EMCS engine management upgrade.
How it works:
As with other EMCS functions, the APR Anti-Theft system is incorporated directly into the engine management computer through software. The Anti-Theft routines are software functions written in assembly code that are run by the ECU's microprocessor. Programming on this level requires an intense understanding of microprocessor architecture but delivers seamless feature integration and unmatched reliability.
If you are an existing APR EMCS customer, adding the Anti-Theft system couldn't be easier. Simply run by a dealer and get your module flashed or use an APR EMCS Home Programmer to flash the EMCS module from the comfort of your own home (we will e-mail you all of the software components.) Alternately, you can send your ECU to APR to have your EMCS module reprogrammed. If you are not an APR EMCS customer, you can get the system by visiting an APR dealer or you can send your ECU to us to have the product installed.
The retail price for the APR Anti-Theft system is $199.
Thanks,
Brett
APR
http://www.goapr.com/Audi/index.html
Also, the link below gives some answers to questions asked earlier in the day. The whole thread is somewhere on page two. If you have additional questions, e-mail to jonathan@goapr.com<ul><li><a href="https://forums.audiworld.com/s4/msgs/1029967.phtml">https://forums.audiworld.com/s4/msgs/1029967.phtml</a</li></ul>
How it works:
Thanks,
Brett
APR
check the link for a little more explanation. IBE is really a hardware based system, very, very different from EMCS. Same idea, but very different execution of it.<ul><li><a href="https://forums.audiworld.com/s4/msgs/1029967.phtml">https://forums.audiworld.com/s4/msgs/1029967.phtml</a</li></ul>
And nothing compares to it. I've had both....I had a APR ECMS chip a while ago, and I loved the functionality of the ECMS. Good job coming out with this added-value feature.
Good luck!
Good luck!
Brett / APR
71
11-21-2002 12:25 PM
