Reposting my question - Whoosh sound with first boost after startup - cause for concern?
I posted this last night, but got no responses.
I recently had my turbos replaced (factory K03's) and am probably more paranoid about sounds from my engine than before, but there is a new sound that has me scratching my head.
When the car is already warmed up (engine oil at least 200 or above) and the engine is restarted, the first time that boost is requested there is a distinctive whoosh of air venting to atmosphere that can be heard from the passenger side of the car followed by a cessation of the sound and the boost starts taking effect.
This only happens on the first such boost request after an engine restart. If I stomp on it after that has occured, I get boost as usual and there is no repeat of that until the next time I shut the ignition off and start back up again.
BPV's are Audi 710N's and I did try swapping the passenger side one out to see if that made a difference - it did not.
I presume that the sympthoms for a failed TBB would not be restricted to the first boost request like what I am seeing (hearing) right now, but would be more persistent.
Any clues to what I am listening to? I did search the archives for info on wastegates and what I could glean about this part of my engine's plumbing doesn't quite seem to apply.
TIA
TIA
Otherwise, the AWE pressure tester is only $15 - worth the money.
There are many things in the S that make funny sounds - not all intake related.
maaliish
09-09-2005 06:59 AM
Radak
03-21-2004 07:15 PM
NW-S4
10
03-21-2004 08:45 AM
AlanL
11-24-2002 04:48 PM
