Revisiting the Oil debates - Mobil 1 15W50 - "designed for high performance"
From the Mobil 1 web page:
Mobil 1 Tri-Synthetic Formula 15W-50:
Flows at -48°C (-55°F), pumps at temperatures as low as many conventional SAE 5W-30 oils.
Provides superior high-temperature protection for <b>high-performance and high-revving cars.</b> (emphasis mine)
Also:
Mobil 1 Tri-Synthetic Formula 15W-50 is especially suitable for high-performance cars, particularly hot-running or heavily
loaded vehicles and special high-tech imports.
S4 is high performance, high-revving, no? Turbos are especially hot-running, no? Seems like 15W50 should be fine, so long as you don't go to the arctic circle or anything... Anyone have any other sources of information?
Thanks<ul><li><a href="http://dallnd6.dal.mobil.com/GIS/MobilPDS.nsf/26b7c4b33367a4a086256665004e4266/9337c5cedcf5e32e852567b60056db77?OpenDocument">Mob il 1 data sheet</a></li></ul>
Also:
just my 2 cents...
porsche uses 15-50 in their new cars, and recommends it. i used it in the summer for a while in a previous car i owned (a somewhat high perf. italian car) and noticed that the car had less power with the heavier weighted oil, which is logical i guess, but certainly not ideal, so i went back to the original grade.
if anything, b/c of the turbos, i would only go as high as a 10, cold weight, and a 40, hot weight- 10 b/c of the need for the turbs to get lubed asap, and 40 b/c of the power robbing qualities (and fuel mileage gets worse too) of the 50. as far as heat goes, if i lived in abu dabi i still wouldn't go higher than a 40 weight...
that's just my 2 cents, i'm no expert, just talking from experience...
intreresting question though, PLEASE READ?
if it's SO BAD to use 15-50 Mobil 1
why does Porsche use it on the 996tt (which has KKK turbo's on it)
I would be surprised if anyone could prove that the BEARING section of a K03
and the K16 or K24 (whatever the 996tt uses) were any different, in there tolerances
hmmmm
Food for thought
hmmmm
Food for thought
