right tail light brakelight stays on when the lights are turned on, ????
my right side brake light stays on when the lights are on even when im not pressing the brakes, had brake light check light on,
Brake light and rear light shares the same slot in the rear light assembly, it is a two filament bulb. Which means, when you turn your lights on, they are suppose to be lite and will only become brighter when the brake paddle is depressed.
"Brake Light" indicator in the center display indicates that one of your brake light bulb is out, and if I am understanding you correctly, that when you turn the lights on, the passanger is lite but the driver side is not, it is the driver side that's burned out and that's malfunctioning, there nothing wrong with the passanger side rear light.
The sequence of the rear light assembly goes as follow:
TOP
Rear Fog light/Driver side only, unless modifications has been done.
Signal light
Back-Up light
Rear light/Brake light
DOWN
TOP
Signal light
Back-Up light
DOWN
I would start by swapping the bulbs and see if it is a bulb issue, as I think you may have an incorrect bulb there.
Is your third brake light working ? If not, it can cause the "Brake Light" warning to come on as well.
Hector4610
19
04-27-2018 07:38 AM
The Chef.
13
12-19-2004 11:22 AM
Dolphin_Vic
NorCal Discussion
10-19-2003 11:12 PM
