rough idle, hard cold starts, misfires, vag results
Old 07-12-2005, 02:15 PM
New Member
jayk_S4's Avatar
Default rough idle, hard cold starts, misfires, vag results
car has been acting up recently, so i decided to purchase a vag com from ross-tech and see if i could figure it out before taking it to a dealer again. any opinions on the following vag results? first vag i've ever pulled but looks to be obviously the driver side o2 sensor before the cat, but would that cause the misfires? thanks
Address 01: Engine
Controller: 8D0 907 551 A
Component: 2.7l V6/5VT G 0002
Coding: 06611
Shop #: WSC 06325
7 Faults Found:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-00 - -
16688 - Cylinder 4: Misfire Detected
P0304 - 35-00 - -
16685 - Cylinder 1: Misfire Detected
P0301 - 35-00 - -
17539 - Oxygen (Lambda) Sensor; B2 S1: Internal Resistance too High
P1131 - 35-10 - - - Intermittent
16534 - Oxygen (Lambda) Sensor B2 S1: Malfunction in Circuit
P0150 - 35-10 - - - Intermittent
16689 - Cylinder 5: Misfire Detected
P0305 - 35-10 - - - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
Readiness: 0010 0001
Old 07-12-2005, 02:17 PM
reefer_bob's Avatar
Default What else is done with the car? Year? Chipped? Other Mods?
Any service lately?
Old 07-12-2005, 02:26 PM
New Member
jayk_S4's Avatar
Default Re: What else is done with the car? Year? Chipped? Other Mods?
Its a 2000 s4 with 81k miles, never chipped (as far as i know) and never modded. I had it at the dealer for 80k mile service, it ran fine for about 1200 miles than started misfiring and the check engine light came on. took it back to the dealer who told me it was my diverter valves, i replaced them, and it still has the same symptoms. not wanting to be misled by the dealer again i decided to vag it myself.
Old 07-12-2005, 03:37 PM
Member
E Vader's Avatar
Default If you haven't already....
...you might want to look at putting new plugs in. Also, I have found good results with raising the idle 20-40rpm on lemmiwinks to address the S4 missfire issue. S4s missfire off the lot new so it is just a matter of maintaning a tolerable amount...IMO.
Old 07-12-2005, 03:42 PM
New Member
jayk_S4's Avatar
Default tried it, plugs didn't fix the problem unfortunately
already tried replacing the plugs, no difference. the car drove perfectly with no misfires (that i could feel) until just a couple weeks ago, now there is a noticeably rough idle and it has trouble accelerating.
Old 07-12-2005, 03:47 PM
Member
E Vader's Avatar
Do you have lemmiwinks?
Old 07-12-2005, 03:53 PM
Member
sj6sp's Avatar
Default Yup, that could goof up fuel trims.
Inspect connections and replace if you don't find anything.
Old 07-12-2005, 03:54 PM
New Member
jayk_S4's Avatar
Default Re: Do you have lemmiwinks?
Nope, do you mean to adjust the idle?
Old 07-12-2005, 03:58 PM
Member
sj6sp's Avatar
Default Check block 032 for right and left side long term fuel trims.
If their is a significant difference between left and right side idle and part throttle trims, that would be more evidence the O2 sensor is the cause.
Old 07-12-2005, 04:18 PM
New Member
jayk_S4's Avatar
Default Re: Yup, that could goof up fuel trims.
Is the o2 sensor visible from above? Just took a look where I thought it should be based on a diagram, but it looks like there are heat shields in the way?
Quick Reply: rough idle, hard cold starts, misfires, vag results
