Rounded Hex Screw
The other day I wanted to lower my KW coilovers and the first step is to loosen the hex screw which holds the perch in place. I ended up rounding off 2 of the hex screws and couldnt loosen the screw in order to lower the perch. Does anyone know what I can do to loosen the hex screw?
TIA
TIA
if so, use a dremel with a cutting wheel and cut a groove in the head so that you can use a flatheaded screwdriver to loosen and remove the hex bolt. Replace with a new one after. If not an EZ-Out might work.
Find a flat blade screwdriver that fits into the hex slot a little tight. Tap the blade into the head of the hex so it's snug and twist. Should work.
The problem with vise grip is that the hex screw is seated inside the perch, so there is no room really to grab the outer part of the screw. This is what the vice grip does right, it grabs and squeezes correct?
Also, what is a Darintake?
cheers.
cheers.
Unfortunately the screw is embedded deep inside the locking perch. What is EZ-Out? Do you know where I can get it?
thanks.
is this link EZ-OUt?<ul><li><a href="http://www.sears.com/sr/craftsman/whatsnew/cr_ct_cooltooldetail.jsp?BV_UseBVCookie=Yes&ve rtical=TOOL&Tool_Id=44">http://www.sears.com/sr/craftsman/whatsnew/cr_ct_cooltooldetail.jsp?BV_UseBVCookie=Yes&ve rtical=TOOL&Too
thanks.
