RPM's drop when coasting to a stop, please help.
When I'm coming to a stop, sometimes I'll throw it into neutral and release the clutch. At about 5 MPH or less, the RPM's will drop and the engine will bog for about a second. If I open the clutch, then everything's normal. I've tried to see if I have a misfire (none) and I've used STP intake cleaner (as per another thread). Any info would be great. TIA guys!
if it helps, I'm running some 1 range colder plugs, and I don't seem to have it; do you have stock plugs?
I'll let you know if a couple of weeks after I've had a good chance to check.
