RS-4 Turbos in stock...
I have VERY FEW OEM RS-4 turbo kits in stock (comes with seals, gaskets, piping, hardware, the usual). $2495. Toll Free 1-866-533-1777. -Pete
-->We also have the O.CT RS-4 turbos in stock as well.<ul><li><a href="http://www.stratmosphere.com/index.htm">Stratmosphere</a></li></ul>
i hve read youre site, but what exactly is done? clipped turbines? or upgraded wheel? i understand its based on the rs4 turbos, but what are the flow advantages, and data on these? thanks.
The blade pitches are altered for earlier torque. They are also "blueprinted" for O.CT prior to O.CT picking them up at KKK. You can see performance details at this link...-Pete<ul><li><a href="http://www.stratmosphere.com/oct_s4_stage5and61.htm">O.CT Turbo Kits</a></li></ul>
will these oct rs4 turbos be compatible with other ko4 chips? or will the maps be off?
Also i want to do some custom engine work as well, that stage5 addresses in a way, which i havent seen from other tuners yet. the used of a thicker head gasket. are you capable of custom tuning for lower compression pistons? and changing the redline higher(say 7800rpm).?
thanks.
thanks.
