RS4 Replicas, mistake
yesterday I installed my rs4 replicas with oem center caps, looks beautiful. But I made a mistake, I used the original bolts, and when I wanted to move the car, it seemed like the handbrake was engaged. I used the original bolts because they are longer than the ones supplied with the wheels. I will be installing them again tonight, with the correct bolts, they just seem a little short. Hope I`m in the right path
if they required different bolts
and you were using longer ones they probably went all the way through and locked up your wheels. Why wouldn't you have at least tried the correct bolts first? :-\
I started in the back and the car had spacers, so i thought
it would be better to have longer ones, then I got exited on how they looked and continued on all corners. Well, back to work tonight.
Hopefully.. you don't have the same problem I had...
See this thread... I had to use (and am still using) 3mm spacers on the front - huge PIA.<ul><li><a href="https://forums.audiworld.com/s4/msgs/1871302.phtml">https://forums.audiworld.com/s4/msgs/1871302.phtml</a</li></ul>
Thanks s4wanabe, I saw your link, lucky me the problem was
<center><img src="http://pictureposter.audiworld.com/90758/mvc-003f.jpg"></center><p>only that the lugs were too long for the front. I changed them an everything is fine. In the back I let the spacers that were on the original wheels, but I will take them off, the wheel is far too outwards, and it has a 30 offset. Here are some pictures, not very good ones but they`ll do.
Jeff Vader - boscoj
11-06-2007 01:39 PM
B7_Imola_Avant
11-25-2005 04:33 PM
Ginseng Sniperâ„¢
10-24-2005 10:17 AM
ploglet
20
06-17-2004 09:01 AM
