S4 Brain trust.. Fault Code issues.
I summon you. S4 people, to help me where i have failed.
I have tried and tried, but there seems that i can not find a solution that will help end the codes, from comming back.
the only one i expect is the airbag one ( damaged ).
17539 - Oxygen (Lambda) Sensor: B2 S1: Internal Resistance too High
P1131 - 35-10 - - - Intermittent
01203 - Electrical Connection between ABS and Instrument Cluster
03-10 - No Signal - Intermittent
00526 - Shareware Version. To Decode all DTCs
27-10 - Please Register/Activate - Intermittent
01589 - Igniter for Head-Airbag: Passenger Side (N252)
32-00 - Resistance too High
00655 - Shareware Version. To Decode all DTCs
32-00 - Please Register/Activate
00779 - Outside Air Temp Sensor (G17)
30-10 - Open or Short to B+ - Intermittent
00849 - Shareware Version. To Decode all DTCs
31-10 - Please Register/Activate - Intermittent
00562 - Shareware Version. To Decode all DTCs
30-10 - Please Register/Activate - Intermittent
00576 - Terminal 15
36-00 - Open Circuit
thnaks for all your help
00576 - Terminal 15
Have you had your ECM out recently? You may want to disconnect it, clean up the contacts and reconnect it?
splice it in and it should be fine (B2S1 would be the driver's side pre-cat sensor).
I've also had the outside air temp sensor code - there are 2 of them - one in front of the radiator and the other you can see only if you take out the pollen filter. I've changed both of mine before - not too hard.
Not sure about the others but this is the car that was in an accident correct? Perhaps the passenger side front airbag deployed and was not re-set correctly?
Now, maybe all of these could just be bad wiring - who knows.
I think the easiest thing to do to see if they are "real" or a wiring issue would be to change the bad 02 sensor and see if that code goes away.
Also, is your ABS/EPS light on or is your brake light flashing? Some have had bad ABS controllers or bad wiring from the abs controller (under the back seat) to the ECU or the ABS pump (in my case).
Distinct
09-13-2004 03:15 AM
