s4 rear caliper same as a4???? brake problems :(
well i was replacing the rear brakes today on m4 s4 following all the steps on the techarticles
anyways the rear caliper is frozen i think we used a press to compact it but now it wont come back out and have completely no brakes after bleeding the rears, didnt touch the fronts
anyone else had this problem??
If you used a press, you need to rebuild the caliper, or maybe even replace it. The pistons have to be compressed with a compressing and turning motion, not just a compression motion because of the emergency brake.
I assume thats true of the A4 as well, as my ex-girlfriend's GTI was that way, as was two Jettas I've replaced rear brakes on.
I'd bet they are, though. The S4's is very similar to the ones on the other cars I mentioned... its possible they're identical, I never really looked that closely, but the way you get them off is the same. The rear rotors are different thickness, though, so who knows.
Brakes aren't something you should be guessing at a cause of a problem with...
The thing I don't really get is why you don't have any brakes at all... unless you are leaking fluid, you should get brake pressure at the other corners...
Are you sure the system was fully bled and isn't leaking?
also bled teh right read and left rear since those were the only 2 we disconnected ???
also wasnt low on brake fluid or anything
brake on dash was flashing
and the ebrake pulls up all teh way but doesnt really grab since the left rear doesnt push the piston in at all
You probably got air elsewhere in the system. I usually do a full flush when I have disconnected a caliper... because the full bleed is good generally, and its an excuse to change out the fluid.
I did a quick front-only bleed when I put my stockers back on today, and I have a mushy pedal, but I'm going to live with it until Saturday when I can do a full bleed. (Not driving it to work tomorrow, anyway, so I only needed it to go grocery shopping). The only reason I only did two was that I couldn't get the rear wheels off (seized to the hub), and I didn't feel like bleeding the fronts enough to be able to stop, putting the wheels back on, dropping the car off the stands so I could roll it backwards to pop the wheels free, just to put it all back up, take all the wheels back off and do a full bleed.
My fronts are fully bled, but the process of changing calipers definitely got enough air in the rest of the system to make the pedal very soft. I didn't disconnect rears.
Send him an email and see if he's still in the holiday giving spirit. Maybe he'll tell you how to do it.
Fixing the front was relatively easy because there was a second piston to push in and pop the frozen one out. On the rears, I bet that there's only one piston per side, so it's probably more difficult.
