S4 and S-03s tire presssure.
Already tried a search. No definitive answers. If you have stock size (225/45/17) what pressures are you running? Trying 38f/36r, but want to see what others have.
that's for street, if i'm running track it would be lower, maybe something like 34 36 or even 32 34 (cold tire pressure)
i'm running stock suspension and 19mm sway, (stasis going on this week!)
higher rear tires presure will help reduce understeering.
KW V2 coilovers
- rebound 25% from soft (F), 40% from soft (R)
- 25.75" F, 25.5" R ride height from fender lip
Neuspeed 19mm rear swaybar on stiff
CPP adj. links
- Camber -1.5, Caster 6.5, Toe .08 (F)
- Camber -1.5, Toe 0 (R)
for track use I increase the front camber to -2.5, set rear toe to 0.08 and drop the tire pressures depending on ambient conditions but always keep the rears +2psi more than the fronts.
Mild understeer going into and mid corner. Neutral attitude (4 wheel drift) during corner exit.
CPP adj. links
