S4 Timing
Follow up to my <A href="https://forums.audiworld.com/s4/msgs/952001.phtml" target="_blank">MAF values post</A>...
Is there a problem with the timing in my S4 and what would be the likely causes?
<B>stock timing under boost</B> -- Looks good... seems to stay in the 5-10 degrees advanced range under boost:
<img src="http://pictureposter.audiworld.com/42712/stock_timing.jpg">
<B>stock timing under boost</B> -- Not so good... drops to negative timing when boost increases:
<img src="http://pictureposter.audiworld.com/42712/chipped_timing.jpg">
<B>Stock & Chipped Timing vs. RPM</B> -- Over 4K RPM, chipped timing goes negative:
<img src="http://pictureposter.audiworld.com/42712/timing.jpg">
Anyone have any thoughts?
These logs are from hot weather (~88 degrees) and fuel was Sunoco Ultra 94.
I've seen identical results running Sunoco 94 from a different gas station as well as similar results on Mobil 93 octane. Some of the other runs were done in cooler temps (mid 70's), but that didn't seem to change anything. Results were similar to the above graphs.
Chip is APR v3.2, 93 octane program.
I'm not sure which gears the logs I posted show --I think they were 1 through 3/4, but the timing drop is visible in all gears when under boost.
It's hard to make sense of this when you log it this way. Try logging starting in 3rd (or 4th if you have room) at about 2K RPM and go WOT to redline. Then plot Timing versus RPM. I have several you can compare to, some in my picture poster I think.
<center><img src="http://pictureposter.audiworld.com/25843/timing.jpg"></center><p>That looks pretty typical for what I and a few others have seen with that chip. FWIW, I asked APR about it and they said it was perfectly normal.
BlackS4tt (Josh)
42
10-04-2006 04:07 PM
2low4snow
09-04-2005 02:27 PM
Pop3
20
10-12-2004 07:47 PM
PhiS4
10-01-2004 10:14 AM
