s4 tranny reverse lights not working....
ok so i bought a stage 3 a4 1.8t with a s4 6 speed tranny swap. great awesome love it. now the reverse lights dont work. i bought the car with everything done to it and i have yet to get in touch with the seller to find out why they dont work. called the stealership and they said it might be the switch... does anyone else have any experience with this at all? i coudlnt find a reverse light fuse at all and the bulbs look to be OK... if one is out could they both go out? I would assume they wouldnt wire it like that but I could be wrong. if it is the switch is it internal?
thanx
josh
thanx
josh
The reverse light switch connector is located on the top right of the trans...
and I am not sure how hard it is to get to without having your trans lowered. I just finished that step in the middle of removing my trans. I would check the voltage at the connector at the firewall first to see if the voltage changes when you put it in reverse.
Good luck.
Good luck.
Longwolf (Christian)
01-27-2007 05:36 AM
Beemer832
12-04-2006 04:56 AM
Zwoobah
Audi Original "S" Cars
16
11-27-2005 09:49 AM
hondakiller
02-20-2004 06:48 PM
