s4lorn, are you running asp k04rs6 fueling? or pj k04 fueling?>>
ASP must have removed the deviation induced throttle cut (the requested is no where near the registered actual) as well as the MAP limit induced throttle cut.
I have experienced TC since I installed all of the hardware/software.
I thought I had a boost leak and checked at least 10 times and could find nothing. I finally just unplugged the ECU and let is sit while I was swapping plugs (saw the ECU hard reset in one of your old posts). After that- no more TC
On those files is surely looked to be caused by the deviation. I am sure that Mark or Mike Moore could tell you what the did on the S/W
i will remote in and at least grab the excel file and take a snap shot and post later tonight.
Dan
Dan
that.
BTW- I have learned, or tried to learn, a lot from your posts. Glad to see you are back.
GoodMatt
16
08-30-2007 11:14 AM
beejohn
03-14-2005 09:06 AM
Mike@VAST
31
08-29-2002 07:01 AM
