Shifting 101: Some n00b questions..
Since the S4 is my first car with a manual tranny, I'm still learning how to properly shift.
I've heard about a lockout to prevent accidental shifting into reverse and 1st, but what about 2nd? Is there a max speed / rpm that would prevent going from 3rd to 2nd with the clutch engaged? I was trying to downshift going through a 90 degree corner < 35 mph when I felt like I was locked out.
Forgive the noob ?, but I'm kind of learning as I go here.
and reverse can be a chore. try again and it should work, especially when you're warmed up. Just obviously don't shift into 2nd at too high a speed (tops out around 60 or so)
If you just rev match while the clutch is in, the only thing you're going to save is the clutch.
To save your syncros you're going to want to double clutch so that the dog teeth in the tranny spins with your control and doesn't require the syncros to do all the work. Of course, it will save your clutch too like rev matching downshifts.
But yeah, rev matching doesn't save your syncros, double clutching does.
conman5353
07-08-2007 03:52 PM
osu s2k
06-16-2006 09:02 PM
bababooey
12-11-2001 07:54 AM
