single turbo 2.7t puts down 500whp
#17
the block. Build that bad boy up a bit and rev that 2.7 a little higher, on top of getting a better tune, I am sure he could easily be in the 10's.
#18
Dynapak dyno graphs always look like that because of the scaling. pause the vid aand look at torque peak--it occurs at ~4500rpm...right where it should. Gt2552r's by comparison reach torque peak at 4800 rpm....and pj k04s around 3600rpm.
Why all the doubt? Homebrewers use K03 code as the standard---u add bigger injectors and MAF--n75 is not in use here.
#19
rev band with that turbo. He also didnt mention what A/R he's using on that turbo...i suspect a 0.63 or 0.82....not to mention as proper tune. timing is key to our cars. the a/f ratio and timing has to be right for power and spool to be optimized. Im sure ASP or Eurocode code custom tune that thing to spool about 300 rpm sooner and put out 20-40whp more across the band.
As the member mentioned...it is a single turbo supra dyno.....because a gt35 is a turbo that Supra's use ....they use something very similar called an SP57....the SMALLESTTTTTTTTTTTTTTTTTT single turbo Supra's use!!!! they make 560whp with a great response.
The Audi guy says he's going gt4088....which I feel is a little laggy on the street....but a great high hp match for our 2.7. Can you say 650whp.
audiquatro75
Audi Original "S" Cars
12
08-22-2007 12:29 PM
Mr.FRU-T-Pants
Quattro: Turbo / Ur / Sport
12-07-2004 06:24 AM
